Curtain Wall Panels-Corrugated Steel
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
mmeyerBV83N
282 Aufrufe, 1 Antwort
The company I work for uses a lot of corrugated sheet metal. I've created a profile for a curtain wall but it's not allowing me to cut overhead doors, windows, nor adjust walls for gables. I've seen this is a common issue concerning Revit, but cannot find anything that's helpful.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: mmeyerBV83N
You can use solid mass to cut the panels.  Cut Geometry: Pick the panel first then pick the mass.
