hi all.
As the object curtain wall is not visible for strcuctural discipline.
How can I solve the problem?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
have you checked the Structural option from Properties for the CW?
Constantin Stroescu
If you want to use CW for this :
instead of using as panel a Basic Wall - - use System Panel Solid with material and thickness. These panels are recognized as Structural too...
Constantin Stroescu
you can also make multiple System Panel Solid by Duplicate....with different material and thickness.
Constantin Stroescu
