I am learning the Review the Basics - Revit (https://customersuccess.autodesk.com/disciplines/architecture/challenges/review-the-basics) course in Revit official site. When I go to the Curtain Walls (https://customersuccess.autodesk.com/course?id=269) part, I encounter this question: the Curtain Wall not Showing in South Elevation View in Revit 2022.
I have uploaded three screenshot about the question, could you please have a look? Thank you.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Select the elevation pointer and check the elevation line, see if it is in front or behind the curtain wall. Also, check the phase of the curtain wall versus other components.
Hi ToanDN,
Thanks for you reply.
I tried your first solution "check the position of elevation pointer and elevation line". The problem solved!!
I placed the "elevation line" at the middle of the house, no wonder I could not see the curtain wall in south elevation view!
Now I place the "elevation line" at the front of the house, then I can see the curtain wall in south elevation view!!
The screenshot as below:
