Curtain Wall Mullions
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
bimitaly
356 Aufrufe, 3 Antworten
I Have to create Horizontal mullion and on the top of it vertical mullions in a sloped Glazing roof. if create like the way one of the mullion getting spacing either horizontal one or vertical one which is i don't want. i tried may ways and checked the option but i couldn't make it.
For better understanding see the attached snip.
i need to make both mullions continues.
Thank you.
Satya Adabala.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: bimitaly
Stack two sloped glazing roofs, one with hor million, one with vertical mullions. Or stack two beam systems.
Nachricht 3 von 4
hmunsell
Mullions in a curtain wall have a priority, there are 4 default options to choose from. Once set, you can modify each intersection manually if needed. BUT one always has priority over the other. Only other option is do as @ToanDN suggests.
Howard Munsell
Nachricht 4 von 4
bimitaly
als Antwort auf: ToanDN
Thanks for your reply.
 Actually i can't make two wall system. however i'll try to use stack two beam system.
if i encounter with any new issue i'll get back to you
Thank you.
