Curtain Wall Joins
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
303 Aufrufe, 2 Antworten
Curtain Wall Joins
I am having issues with my glazed curtain wall cutting the original wall at the corner.
I have embedded the curtain wall within a wall and I have joined the curtain wall at the corners.
They are also both on the same phase.
Any suggestions for how to solve this?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I have decided to edit the wall profile to solve this issue as cutting with just the curtain wall did not give me a completely clear corner edge.
Nachricht 3 von 3
vincent_bergeron
It's a limitation of the curtain wall panel, that's why I think you might want to consider adding your vote to this idea:
https://forums.autodesk.com/t5/revit-ideas/more-realistic-curtain-wall/idi-p/7531182
