Hello I am trying to get a curtain wall system to join to a roof but its not working i have tried using the edit profile setting but get the same issue. I get translucent grid come up but it will not cut the panels to an angle.any ideas thanks?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Select the curtain wall, and then Modify>>Attach Top / Base. Then select the roof.
All else failing, please share a file.
yes this is what i have tried and it didn't work see attached file..
Is this a 2018 file? Rats. I only have 2017!
ok makes sense but this is a kingspan model i would have thought they would have modelled it with that in mind. What about if i did a cut on the wall panels to cut the angle in?
its a shame the kingspan panels are not set up to be adaptive as you mentioned there're a big company i would of hoped they would..
Make a normal wall where the curtain wall should be, attach it to the roof, than change the type to curtain wall
