Curtain Wall in External Leaf of Cavity Wall Only
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
532 Aufrufe, 3 Antworten
This is my first of hopefully many posts on these forums.  I'm learning how to model curtain walls in Revit 2021 at present and am happy enough with placing a curtain wall in a cavity wall.  However, the curtain walls on this building are embedded in the external leaf of the cavity wall only with insulation behind all non-window panels as you would expect.  The internal breeze block leaf is still present behind the wall.
Please could someone give me some advice on how to model this in Revit?  I'm sure it's just down to how you embed the curtain wall into the cavity wall but I can't seem to work out how to do it.
Thanks to all for any help in advance!
Keiran.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You can use Cut tool to manually cut the main wall with the curtain wall even though it does not sit in the main wall.  For this type of design:
Nachricht 3 von 4
Are you familiar with embedding walls?  Embed away!
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-68DB5265-BF43-45E3-AB8C-AC7813310548-htm.html
Nachricht 4 von 4
martijn_pater
I suppose you could also draw the external wall layer seperately or do as Toan suggested...
