Curtain wall - glazing shown as solid
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
ButterworthStudio
3590 Aufrufe, 3 Antworten
I've followed tutorials to insert curtain walls - for some reason that I can't fathom, mine are not showing as transparent, but as solid.  I can't understand why - they are set to glazed in the properties.  Windows are showing as transparent.
Any help gratefully received.
3 ANTWORTEN 3
Nachricht 2 von 4
Avaris.
als Antwort auf: ButterworthStudio
Could you also place a screenshot of your material? Applied to that panel?
Project Browser > Family > System Panel > Material. Or tab into you panel and edit type.
I guess that material does have no transparency.
Nachricht 3 von 4
ButterworthStudio
als Antwort auf: Avaris.
Thank you - in asking for the material info, you sent me looking a bit further into my settings for the panels, from there is was easy to identify the problem, I picked the glazing finish and I'm really pleased to say all is working fine now - thank you ever so much for your very speedy reply!
Nachricht 4 von 4
Avaris.
You can mark it as a solution to help other people find the answer quickly.
