Curtain Wall Fence With Door
5 ANTWORTEN 5
Nachricht 1 von 6
dm0144
313 Aufrufe, 5 Antworten
Any idea how to add a normal width door (around 90 cm width) to the curtain wall fence with the same vertical posts and same distance between them?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: dm0144
If you want the actual door with swing and whatnots then model it as a curtain wall door with extrusion to match the vertical fence posts.
If it a one time kind of deal then then add curtain grids to match the door opening > remove grids segments inside the door opening to merge the it into one panel > duplicate the curtain wall type and modify to create the door-like structure > replace the panel with the new curtain wall type > create a in-place door family to add swing lines for plan and elevation.
Nachricht 3 von 6
Something like this?
Nachricht 4 von 6
Actually, you are describing something more like this:
You would need a special hinge as well as top/bottom rails and header.
Nachricht 5 von 6
dm0144
als Antwort auf: barthbradley
@barthbradley Yes, exactly only without the top/bottom rail on the door and no header.
Do you mind sharing the family?
Nachricht 6 von 6
There is no family. It is another curtain wall infill as a door.
