I want to keep the ability to edit the curtain walls. Can I, or can I not do this with assemblies? Some people are alluding to this possibility. How can I exit the assembly and edit the curtain wall? It seems like I can't do anything with it once outside the assembly. Seems pretty idiotic that you would be limited when modifying assemblies, so I'm assuming that this is something I'm missing.
If you can't actually edit assemblies, I will keep isolating the curtain walls unless someone has a better suggestion.
I've created a curtain panel legend in order to dimension everything.
I've created a tag that works for individual panel marks which allows ppl to actually find their panels.
What I would like to do is organize the curtain panels by their curtain walls: group them via the mark of the curtain wall to which they belong in the schedule. Is this possible? I'm also looking to get an idea of each individual curtain wall's total area by doing this. Still possible? At the moment I'm actually creating new type families for the curtain walls. This provides a type mark organizer in the curtain panel schedule.
If this is not possible is there a recommended way of organizing these curtain wall panels so that they can be a little more legible?
Finally is there any way of combining the window and the curtain wall schedules? Again, I'm looking to get information regarding total areas.
Almost forgot. If I have a curtain wall awning in one of the curtain walls, it gets counted as a window, not a curtain wall. This seems a bit confusing. How can I change this?
