Curtain Wall Door
20 ANTWORTEN 20
GELÖST
Nachricht 1 von 21
2671 Aufrufe, 20 Antworten
Curtain Wall Door
I did not create this family, and I think it's a bit over my head. It won't adjust to the height of the curtain panel. Is there an easy fix? I like how the rest of it functions for me... Thanks.
20 ANTWORTEN 20
Nachricht 2 von 21
als Antwort auf: Anonymous
I don't have Revit right now but you can try to lock the geometry of the door to the top reference plane in the family.
Nachricht 3 von 21
als Antwort auf: ToanDN
already tried, doesn't change a thing.
Nachricht 4 von 21
Sahay_R
Try this. Now the panels adjust to the frame.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 5 von 21
als Antwort auf: Sahay_R
i am in 2014...what did you do? i'll try to replicate it. unless you have 2014...
thanks!
Nachricht 6 von 21
Sahay_R
For some reason, the frame didn't like the top reference plane. I
1) removed the existing constraints - the Height dimension and the lock on the frame
2) created a whole new top reference plane,
3) locked the top frame to it
3) dimensioned the height and gave it the Height parameter
Rina Sahay
Nachricht 7 von 21
thanks. that worked. one more question. i tried putting it into a large opening, but for some reason the door panels don't flex in size...see clip. thank you.
Nachricht 8 von 21
Sahay_R
Remove the Width dimension from your family. Leave the parameter.
1)
2)
Rina Sahay
Nachricht 9 von 21
my width parameter is reporting, and i can't modify it.
Nachricht 10 von 21
Sahay_R
There is a little pencil at the bottom left of the dialog box. Highlight Width, and click the pencil. Yes you can edit reporting parameters and remove the reporting - I did that for the height.
Rina Sahay
Nachricht 11 von 21
if i remember correctly, that's a "new" feature...2014 kind of sucks. and the more i look at this family, the worse it is. i guess i didn't get the height to work, yellow line is where it is, and green is where the curtain wall stops. and in elevation it only shows the door open...so, i'll try something else. but thanks for trying to help.
Nachricht 12 von 21
Sahay_R
Click on one of the panels. Make sure that Panel Height in the panel family is associated with Panel Height in the door.
Rina Sahay
Nachricht 13 von 21
One more thing to do.
1.   Make "Height" parameter to be Shared
2.   In Project, load the "Height" Parameter in the Project parameter section.
Otherwise it won't read and flex it.
Hope this helps, Dan
Nachricht 14 von 21
Sahay_R
Some thing that might be helpful, since curtain wall doors are a pain -
Recreate the family. Use the door family template, nest the panel families, apply the parameters as have been shown in my previous screenshots. This will give you significantly less grief - trust me on this.
Rina Sahay
Nachricht 15 von 21
I'll try that, thanks.
Nachricht 16 von 21
You cannot create a family from a door template and insert it as a curtain wall door. It must be created using the curtain wall door template. You can nest other families in it to create the folding panels to control the array more easily.
Nachricht 17 von 21
Sahay_R
@ToanDN - what we have been doing is to replace the curtain wall panel with a wall, and then drop the door into it. As a result we no longer have curtain wall doors in our library. They were too much of a pain.
Rina Sahay
Nachricht 18 von 21
What sort of troubles do you have with curtain wall door families?
Nachricht 19 von 21
Sahay_R
Not sure - they date to WAY before my time. Suffice it to say that here in my organization, Curtain Wall Doors are a dirty word......
Rina Sahay
Nachricht 20 von 21
But I need doors folder containing multiple choice. Where from I download library/doors of Door*.raf files
Thanku
