I need to insert a double door into the curtain wall and I have found this curtain wall door family. However I am not able to use it, the "create instance" is grey out. Edit Type is grey out, how to fix this ? I have attached the family here.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Select a curtain panel in the curtain wall and change it to the curtain wall door type.
But now I have another question which is related with phasing. This is an existing storefront, we will remove the door in new construction but keep the rest. However, when I click the door , phasing is gray out, how can I make it demolished in new construction?
No you cannot deviate phasing of panels from the curtain wall. Here is a workaround:
- model the curtain wall under Existing phase
- set the panel you want to replace to Empty System Panel
- place another curtain wall in the hole, edit the curtain type so it match what supposed to be there, if you need to show an existing elevation; set this in0fill curtain wall to be demolished in New phase
- go to New phase, paste or place the in-fill curtain wall in the hole, change the panel to door
The infill curtain wall will have to have frames that overlap with the rest of the curtain wall. I assume no way we can created just two curtain wall door panels without frames?
Yes you can. Edit the in-fill curtain wall type and remove all frame assignment.
See example file attached. Pic below show existing condition, existing & demo, and new, from left to right.
