Curtain wall - Diamond Grid on Curved Wall
4 ANTWORTEN 4
Nachricht 1 von 5
bchaney0927
1152 Aufrufe, 4 Antworten
[Revit LT 2021]
I would like to have an angled grid on a curved curtain wall, kind of like the London Gherkin but not as big...  and it would be a simple curved plane...
After trying a few different things, it looks like I will have to simply create individual straight curtain walls that have their own grids angled and manually aligned.  Are there any alternatives to this?
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
bin
als Antwort auf: bchaney0927
You can try Mass - Divide Surface - Rhomboid Pattern.
Nachricht 3 von 5
- Create a cylindrical mass
- Divide surface and set UV distances or divisions
- Create a Curtain Panel pattern based family  and set the pattern to Rhomboid, load in the Mass
- Select the divided surface and set it to use that family.
Sample file attached (2019)
Nachricht 4 von 5
bchaney0927
als Antwort auf: ToanDN
Thank you for this, ToanDN.  Would I be able to do this with Revit LT?
Nachricht 5 von 5
Unfortunately no. LT does not support conceptual mass modeling.
