Curtain Wall Corner Mullions
14 ANTWORTEN 14
Nachricht 1 von 15
7194 Aufrufe, 14 Antworten
Does anyone have a functional 45degree Corner Mullion family, for joining 90 degree walls.  I can edit it.  So don't worry about the exactness of it.  I am making a Kawneer 1600 corner.
Thank You
Nardo
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Anonymous
Download it through the Manufacturer's link to BIMObject.
...here's one: http://bimobject.com/en-us/kawneerna/product/21014
Nachricht 3 von 15
als Antwort auf: barthbradley
I see normal components there on the "BIM Objects" site, but I don't see a corner mullion.  Please check the image below.  If you have a link to such a file, that would be great.
Nardo
Nachricht 4 von 15
You need to drill down into the Project Browser. They are both listed there.
Kawneer-1600_LR_7-14 Mullion_V-Corner and Kawneer-1600_LR_7-14 Mullion_L-Corner
If you want it modeled more accurately, then you will need to build the family yourself. You can pull Architectural Details from the Kawneer website to guide you, but keep in mind, this is what they mean by "over-modeling". My advice: save that LOD for Details.
Nachricht 5 von 15
I'm building the Curtain Wall Model for the Manufacturer.  So further detail is required.
I've seen such mullions in live models before.  But I wasn't at the helm.  So I couldn't check and see if it was a modeled in place element.  That's what I normally do.  I'm trying to expand my library of functional stuff that works like it should.  These corners are popular.  I'd like to have one that I can just edit to the specifications of my detailers for each project.  The ones I have modeled from scratch always have some issue.
Thanks.
Nardo
Nachricht 6 von 15
stingers80-cgarchitect
Just wondering if you found a good way to make that corner mullion?
Nachricht 7 von 15
als Antwort auf: stingers80-cgarchitect
See attached.
Nachricht 8 von 15
als Antwort auf: ToanDN
Do you have this file available in 2018 version?
Nachricht 9 von 15
How do you get the horizontal mullions to cut properly? I had already created my own corner mullion, but neither horizontal, to the right or left, cuts properly.
Nachricht 10 von 15
Is "Corner Mullion" checked?
Nachricht 11 von 15
No, it's greyed out.
Nachricht 12 von 15
Nachricht 13 von 15
Thanks~ Works great on the border horizontals (top / bottom) but not on the intermediate horizontals.
Nachricht 14 von 15
Works fine on any horizontal mullions.  You need to play with toggle mullion join a few times.
Nachricht 15 von 15
Ah ok, yes. I was using the "toggle mullion join" control on the mullion segment. When I select both segments and use the Make Continuous command, they join properly.
Great~ Thank you! I have a much simpler curtain wall system now.
