New to create curtain wall door. I applied the width parameter to change the door width. It runs into the constrain issues. Could anyone give me some advice to solve this problem?
Thank you for your help in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
That's not how a Curtain Wall Door is parametric. The width of a CW Door is parametrically controlled by Revit in the Project on placement. The width is equal to CW Panel that it replaces. Open an existing CW Door Family from the stock Revit Library and see how it's built.
BTW: The Import Symbol in your CW Door Family cannot be sized parametrically. It's width is fixed.
Door Width should be a Reporting parameter.
The Import Symbol is useless, get rid of it. If you must use door details from the DWG, edit the DWG and wblock the profile part (shown red below), import it in a detail component family, load the family in and place at either side of the door, and constrain to the left and right ref planes.
