hi, i changed the louver panel to empty system panel how im going to bring back the louver panel. undo is not an option. thank you
i tried that so many times using TAB to select but cannot select anything (i really dont know what is the reason?) at the end i have to redo it again. thanks you for your time.
Hi @BIM_Dreamer
Did you use a downloaded custom louvre family?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Do you have your cursor over the "edge" of the Curtain Wall Panel when you are Tabbing? If so, you should cycle through Curtain Grid, Curtain Panels (each side of the grid line, etc)- until you get to the panel you need to select.
Hi @BIM_Dreamer
If you find posts have helped with your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
Viveka CD
