Curtain System Mass face orientation
jagostinho74
jagostinho74
Cannot seem to find what is going on with the Mass and Curtain System associativity.
Trying to create a Curtain System using custom Curtain Panels with Offset parameter. Positive will generate outward panels and inward panels. Seems to happen when Mass face has a grip on it. Not sure what else might be going on.
A couple of questions.
1. Why is it that the grip only shows in a couple of faces and not all?
2. How can we make all Mass faces orientation the same so that a workable Curtain System and Curtain Panels can be used?
File attached.
Many thanks.
Joaquim
Assistant BIM/CAD Manager
Manchester, UK
alan.quinn
I understand you have questions on creating curtain systmes with parameters from a MASS face in Revit 2015. Please see my comments below.
You said: Trying to create a Curtain System using custom Curtain Panels with Offset parameter. Positive will generate outward panels and inward panels. Seems to happen when Mass face has a grip on it. Not sure what else might be going on.
My comments: I tested and the Number in Grid 1 and 2 is not working as expected. Also, I'm not sure how you got to this point, its not clear what your workflow was.
You said: 1. Why is it that the grip only shows in a couple of faces and not all?
My comments: Again, I'm not sure on your workflow or what your image is referring too.
You said: 2. How can we make all Mass faces orientation the same so that a workable Curtain System and Curtain Panels can be used?
My comments: Again, I'm not sure on your workflow or what your mean by the above question.
Here's a link I mailed out before on offsets.
+/- offset(s) for families
