I have placed a curtain system on an in place mass and I can not get the instance to adjust the grid angle. I drew one side of the form and was able to see an angle instance input under the grids and then when I went to the other side, the grid angle instance field was gone. I can not get the curtain wall grid to be at 0 degrees, it is fanning to the shape of the form i.e. instead of being parallel lines, it fans out to equally distribute to the form face.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Take a look at this similar topic.
This reference is exactly my issue. I get the concept of the work around and will give it a try. I don't understand how I got the first face to have an instance that does have a field for grid angle and moving forward I do not have that instance field. Is it possible that I deleted the option for a grid angle?
If you look at my attachment, the curtain grid on the left has the grid fanning. I do not have grid option to set the angle. If you look at the right side you can see the verticals all nice and parallel as I want, when I hit the properties of this grid it does have an option for a grid angle.
And here is how I propose to fix it.
Do not use Curtain System on the non-planer surface. Divide the surface using intersect with reference planes.
Use pattern based curtain panel family.
Result:
Thank you all.
I have a sense that I may have warped the in place mass I had created and the two end faces may have been slightly curved and the curved sides could not create an angle instance. I wish there was a way to lock the in place mass to keep it from being sensitive to this. Also, the grips and the distance fields are hard to position.
I ended up drawing a bunch of masses and eventually was able to replicate what I wanted. I think what I found was that when you clicked on an in place mass you saw within it a series of arrows up and sideways. Perhaps for some reason you might not be able to do all sides?
I appreciate the work around approaches. I find it somewhat frustrating to have to back up a work flow and come at it from a different approach because Revit doesn't like something and can not tell you. Once I am an expert and can figure out a hundred ways to skin a cat, it won't be a problem, but it is frustrating.
Thank you again.
