Curtain panel pattern based
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
433 Aufrufe, 1 Antwort
Hey,
I am trying to make a curtain panel(pattern based) in which i have made a void, When i select the mass panel including void i can't see the "Divide Surface" option contrary when i select the panel without the void i can see'it. I want to divide the surface with void and apply the pattern.
Thanks in advance.
Ar. Lochan
1 ANTWORT 1
Nachricht 2 von 2
Alfredo_Medina
als Antwort auf: Anonymous
@Anonymous
Keep using the Tab key until you can read: "Form: Joined Solid Geometry: Face".
