Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Here is the Revit file I've been testing with. Thank you.
See screencast and revised file. You need to fix the top bar of the panel family so it constrained correctly, right now it is flipped to the other side of the panel when it is not horizontal.
https://knowledge.autodesk.com/community/screencast/7b66b62f-307b-4013-914e-be39b4792fc8
