I have made a custom solid curtain panel to show a corrugated metal appearance.
I am not happy with the join condition at the corners. The issue also causes a graphic problem when TL is turned off, as there is a dark wide line at the corners.
None of the options in the menu seem to change the behavior of the panels join condition though.
Hi
I believe you will need to create a custom corner pannel for this one. Both left and right joint.
