Curtain Panel Area Broken For Sloped Glazing Roof
8 ANTWORTEN 8
Nachricht 1 von 9
JOfford_13
715 Aufrufe, 8 Antworten
The area reported by a curtain panel is wrong after performing the following operations (see video for demo).
1.  Create a Roof By Footprint
2.  Assign any Sloped Glazing roof type
3.  Create one curtain grid line
4.  Delete the curtain grid line
5.  Rotate the roof element, in plan, by something other than a 45 degree interval
In the example the correct area is 100 SF.  The farther away the roof is rotated from 90 the worse the error in area becomes.  Rotating the roof 30 degrees from vertical produced an area of only 50 SF, half of the actual area.  At 45 degrees from vertical the panel reported the correct area.
This appears only to be an issue with flat sloped glazing roofs.  It also seems to behave fine before the curtain grid line is added and removed.  Please advise.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: JOfford_13
Yes I can replicate it.
In case you are interested on how to fix it:
Annotation 2019-04-16 112635.pngAnnotation 2019-04-16 112553.pngAnnotation 2019-04-16 112615.png
Nachricht 3 von 9
JOfford_13
als Antwort auf: ToanDN
Interesting work-around but easy to forget and very time-consuming
Nachricht 4 von 9
Correct. By the way, you only need to change one grid orientation, not both like I did.
Nachricht 5 von 9
@Viveka_CD
Any thoughts on this?
Nachricht 6 von 9
Viveka_CD
@ToanDN  thanks for the alert and screenshots, let me do some research and check if there is anything logged already.
Nachricht 7 von 9
Viveka_CD
@JOfford_13  @ToanDN
In communication reg this issue with the dedicated resource, will update.
Please ping me in a few days.
Nachricht 8 von 9
JOfford_13
als Antwort auf: Viveka_CD
Any updates on this?
Nachricht 9 von 9
Viveka_CD
Hi @JOfford_13
Currently the team is working on an Improvement feature regarding this issue for Surface Area Calculation for Single-Sided Panels
Please check back in a few weeks for further updates on this.
