Curtain Louver with recessed mullion
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
943 Aufrufe, 2 Antworten
I want to create a curtain wall where the mullion is recessed back in to the curtain wall so when you looked from the outside the curtain panels are the only ones that is seen and the mullions are behind. i have attached the plan form of the design that i need. when modeled in revit and the mullion was given an offset to the back the glass panels join together i want the panels to be spaced while the mullion is recessed back.
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
give offset to Mullion as well as panel..give offset to Mullion as well as panel..
I have uploaded Revit file for your reference.
https://www.dropbox.com/sh/o374nhbprrh0bw9/AADmJFxfotJIx4cVzq6hoQVta?dl=0
Best luck..
Corsten
Building Designer
Nachricht 3 von 3
Seems to me that you could achieve what you by using the stock Rectangular Mullion and changing the "Width on side 1" and "Width on side 2" parameters.
