At least once every work session, my cursor arrow will disappear. I can still move the mouse around, and I'll see items being highlighted, but I can't see the actual cursor. It's making it very difficult to work. I can't seem to reproduce the issue. It does seem like it disappears more often when I'm hovering over the Project Browser. Has this happened to anyone else?
FYI, I just upgraded to Revit 2019. Never had this issue with 2018. Currently using it on a Mac with Parallels.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
No, I use a USB mouse. It happens even if I switch to the trackpad. Thanks though!
I wonder if it's an issue with my graphics card.
Hi @Anonymous
Did you check the system requirements and compatibility for Revit 2019?
Also, download and install a new copy of the graphics card driver from the manufacturer's website.
If not, please try a reinstall of the Parallels Tools from within Windows and make sure the USB receiver is enabled in case of a wired mouse?
Let me know if this helps resolve your issue.
Looking forward to hearing from you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Viveka_CD, I checked the system requirements again, and it looks like I don't meet the memory requirements. Didn't seem to be an issue running 2018, but definitely seems to be an issue for me with 2019.
Also, I ended up disabling hardware acceleration, and that seemed to do the trick-- no more missing cursor!
Thanks all.
Hi @Anonymous
Thanks for coming back and replying!
Glad to hear that your issue is resolved. ![]()
A few AKN articles to help the community seeking answers to similar issues:
Viveka CD
HI I am editing text in a Legend Revit 2020.2 The cursor blinks or flashes 5 times, then disappears! When scrolling up or down or left to right the cursor disappears. This is annoying and would appreciate if someone can tell me how to fix this. If it can be fixed!?
I have tried this on another PC with similar config and get the same problem.
PC: I Xeon(R) CPU E5-1650 v4 @ 3.60 GHz
RAM: 32 gb
Video: NVIDIA Quadro M4000
