Current Revision parameter control of revision field visibility
1 ANTWORT 1
Nachricht 1 von 2
sandris.metlovs
434 Aufrufe, 1 Antwort
Hi, i am making title block for my organization where revision field field is separate from title blocs itself and appears only when actual revision on sheet is made. In title block is inserter Label with "Current Revision" parameter.
Is here any way to use Sheet category based parameter as visibility check status like. "Visibility" on if Current revision > 0 ?
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: sandris.metlovs
Sadly you can't use any of those parameter to drive the visibility.
