I was wondering if it's possible to get the "system" dimensions (not sure what to call them) to show metric and imperial at the same time.
That would be those blue "preview" dimensions you get when you select a wall, and it references other walls parallel or perpendicular to it.
I've attached an image circling the "system" dimensions I was hoping to get to show both metric and imperial.
As you can also see, I know how to set it so that annotative dimensions show both metric and imperial. If there's no way to do the above, I'll just dimension everything and be off with it.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Blue ones are called "Temporary Dimensions" and they use the "Project Units". Stacking "Alternative Units" is not possible with "Temporary Dimensions" OOTB. Can do with permanent dimensions though.
