Does Revit, like ArchiCAD has a option for cumulative dimensioning?
Gelöst! Gehe zur Lösung
Gelöst von noratemajSNN9J. Gehe zur Lösung
Gelöst von Gerdes~. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Don't know what you mean by "Cumulative", but Revit can do continuous dimension strings automatically. Activate Dimension and check the Options Bar. Pick Entire Wall and Auto Dimension Options.
....or maybe you want Baseline?
Yes, it has the same option as Archicad.
Just go into the "Type Properties" of your dimensions and change the "Dimensions String Type" to "Ordinate". (the last Option of the three)
I would provide Screenshots but my Revit is in another language.
