Crossing of sweep's element and window's protrusions
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
brian_adams
662 Aufrufe, 8 Antworten
8 ANTWORTEN 8
Nachricht 2 von 9
Ilic.Andrej
als Antwort auf: brian_adams
Use Align tool.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 9
brian_adams
als Antwort auf: Ilic.Andrej
Thank you for your fast reply, but  would you be so kind to put an answer on this forum, I have not registered on Linkedin.
Nachricht 4 von 9
Is that a wall sweep you are referring to?  Select the Sweep and then grab the blue dot at the end of it and drag it away from the Window Opening.
If that doeesn't work, you are welcome to post you file here as well.
Nachricht 5 von 9
brian_adams
als Antwort auf: barthbradley
I guess this tip written by you  is  really good solutions. But in other  case when   sweep's element is part of the wall's profile , edges are not editable.
Nachricht 6 von 9
Uncheck Cuttable and Cuts Wall under Sweep Properties in Wall Properties
Nachricht 7 von 9
Nachricht 8 von 9
like I said before; if that doesn't do it for you, then post you file so we can examine it.  Not all sweeps are created equal.
Nachricht 9 von 9
brian_adams
Thank you
