Cross line display in plan laout
Message 1 of 15
I have problem about my project file showing cross line, can't make select the line ( like hidden or invisible. don't know)
I want to remove that cross feature line from plan layout, elevations, sections.."every where its display".
pls, help me....
you can see its on attached image files.
Thank you,
regards,
amsdsg
Replies (14)
Message 2 of 15
ennujozlagam
set you underlay to none.
Message 3 of 15
Thanks dear for reply. I did your solution.
 but, still that cross line there......
Message 4 of 15
Does the line have properties? Can you select it and tell us?
Message 5 of 15
ennujozlagam
hello, try to untick your use hardware acceleration from options > hardware and see if helps. thanks
Message 6 of 15
No can't select line. its look like overlay line.
Message 7 of 15
So, the question is: What can be seen in the view, but not selected? Sounds like a riddle?  Well, I know a background cannot be selected -- but that's not what it looks like in your screenshot.  How 'bout posting the file for us to examine?
...Question: Are any of these boxes unchecked?
Message 8 of 15
constantin.stroescu
Constantin Stroescu
Message 9 of 15
I got a solution abot my problem, which I mentioned that cross line display in plan layout.
I changed the  material which I assigned to ground floor and 1st floor (2 story) then that cross line disappeared.
But, I have no any idea, why is that. becoz i'm not a expert in revit.
Thanks lot all of guys involved to give me big help to solved my problem .
Thanks again. see you guys again with another problem...lol
regards,
AMSDSG
Message 10 of 15
Could be an issue unrelated to Revit too. Hard to know. Sometimes weird sh*t happens.
Message 11 of 15
The floor material and the wall material (could be one material) are defined with a huge diagonal cross pattern.  Edit the material(s) and set the surface pattern to None.
Message 12 of 15
you are awesome!
Message 13 of 15
wong.qiuyu
Maybe your view range. Seem the room cross line only appear at FL+0
Message 14 of 15
JJanssenJ9Y6N
I had the same issue here in the future with the reference lines in an area plan. Turned them off in the view template model settings under AREAS as shown and they went away. (I had to re-select the color scheme as well).
Message 15 of 15
melmoumni
Excellent! I was looking how to remove these.
