Cros section description
is there a way to make cross sections description symmetrical???
In my case value 12 is offset!!!
How should I set fonts when edit families for this kind of "problem"? I'd like that in all circumstances cross sections descriptions are symmetrical!
Regards!
Alfredo_Medina
The original section with symbols is symmetrical. This is a custom section symbol. Then, check the properties of the custom family. Maybe the text is justified to something that is not middle and center.
Thanks Alfredo.
How do I access edit family button? When I double click cross section line it doesn't show up in modify menu....
When I select cross section line and right click with mouse button, edit family command is grayed out!
Thank you!
