Cropping image on TitleBlock
3 ANTWORTEN 3
Nachricht 1 von 4
540 Aufrufe, 3 Antworten
How do you crop an image on a title block?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You already have the dimensions so you can do it in PhotoShop using those dimensions.
Nachricht 3 von 4
als Antwort auf: ToanDN
When I do it, it comes in pixelated
Nachricht 4 von 4
When you reduce the dimensions of an image in PhotoShop, you also need to increase its DPI so that the resolution remain the same or close to the same. For example, the original image is 10" x 10" @ 72 dpi, if you change the size to 1" x 1" then you need to change the it to 720 dpi to maintain the image resolution.
