I have created a sheet with plans, etc, however I need to crop the plan view slightly.
Usually I have managed to turn the crop box visibility on and off with the bottom button however this time I cannot get the crop box to appear.
Am I looking in the wrong place or do I need to create a new one, if so, how would I do that?
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Are you using Design Options?
In that case -
https://forums.autodesk.com/t5/revit-architecture-forum/crop-region-not-visible/td-p/2950972
Yes thanks! The crop view was hidden and was much larger than my visible plan.
