Interesting thing....I'm looking at my 1st floor plan and I have the Crop View checked. When I uncheck Crop View (CV), some of my wall section tags either stretch out longer and/or the head/tail flips positions. now, the sections are no where close to the CV outline and the Far Clip Offset is well within the CV.
any particular reason?
Thanks.
Howard
Hi @htews
Did you resize you crop view? Make sure it intersects the plan view’s view range.
By default the crop region and view range must intersect for a section tag to be properly visible in plan, elevation and other views.
I would be happy to take a look if you would like to post a sample file for troubleshooting. Please let us know if further assistance is needed from the community on this post. We are happy to help wherever possible. Thank you and we look forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @htews
I just wanted to follow-up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
