Crop Region invisible unless Crop View is enabled
10 ANTWORTEN 10
Nachricht 1 von 11
james
1004 Aufrufe, 10 Antworten
I'm building a template in Revit LT 2018.  The Crop Region is not visible, nor hidden, unless I enable the Crop View.
I believe it was my experience in the non-LT version that you could have a crop region visible without the crop view enabled, but is this not correct?
I'd like to have the region visible on the template but without enabling the crop view.  Is this possible?  Thanks for your help.
10 ANTWORTEN 10
Nachricht 2 von 11
Sahay_R
als Antwort auf: james
Make a copy of the offending view with detailing.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 11
james
als Antwort auf: Sahay_R
Thank you for the suggestion, but that didn't solve the problem.
Nachricht 4 von 11
chrisplyler
I am able to have a Crop Region visible, without having the Crop View setting enabled. Just shows the rectangle there but doesn't do anything.
Nachricht 5 von 11
james
als Antwort auf: chrisplyler
That is exactly what I want.  Sometimes the crop region appears with the crop disabled, other times not.  Seems inconsistent.
Nachricht 6 von 11
james
Thanks for the suggestion, but unfortunately that didn't solve the problem.
Nachricht 7 von 11
There are two boxes, one is to crop the view, another is to control the visibility of the crop region. Check the second box.
Nachricht 8 von 11
james
als Antwort auf: ToanDN
Thanks for your reply, but please re-read my post.  I am well familiar with the two checkboxes for controlling the crop.  I'm saying that even with the Crop Region Visible box checked, the crop region is not visible in all views.  With the Crop View and Crop Region Visible boxes checked it's visible all the time.
Nachricht 9 von 11
chrisplyler
Something I have noticed from time to time...the crop region border doesn't always redraw itself immediately after a change in state (checking or unchecking the visibility setting). Sometimes I have to scroll zoom in and out a bit for it to redraw correctly.
But that is the only inconsistency I've ever noticed. Perhaps something is going on with your computer graphics? Do you notice any difference if you change the setting for whether or not Revit uses hardware acceleration?
Nachricht 10 von 11
james
Thanks but no, no difference whether I zoom in and out or otherwise "refresh" the screen.  Having hardware acceleration turned on or off doesn't make a difference, either.
Nachricht 11 von 11
chrisplyler
Bummer.
Hmmm.... a longshot... but do you perhaps have those views associated with a scope box?
