Crop region border is not visible on cad layout and another wider border visible
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
ams1511
3445 Aufrufe, 8 Antworten
I have more than one section views on a sheet and i set its properties as shown in the picture
When I export sheet to cad dwg file, I don't know why I can't see crop region border on the layout, and another wider border that surrounds the whole view is visible instead!!
Regards
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: ams1511
Have you looked into your DWG/DXF Export Setup under Export Options?
Nachricht 3 von 9
Wild guest - annotation crops?
Nachricht 4 von 9
chrisplyler
als Antwort auf: ToanDN
Seems obvious to me that the boundary - when excluded to dwg - probably must be made to include the extents (width) of the Level datum in those views. I'm no Autocad guru, but I don't remember any functionality in Autocad to have any sort of crop boundary that works on elements but allows annotation objects outside to remain visible.
It is my opinion that the best option in this case is just to turn off the Crop Region Visibility prior to exporting.
Nachricht 5 von 9
RDAOU
Hi @ams1511 and everyone (smile)
Ams1511 what you are observing is a normal behavior...what you have exported to AutoCAD is the viewport (that is the Frame you currently see in your AutoCAD Image... When you Export a "Sheet" the Frame of the VIEWPORT which includes7encloses all elements showing on that sheet End to End is what will show in AutoCAD (the purple frame on the rightside Image below)...ie: in this case it is determined by the extents of the Level Datums on your sections in Revit. See Image below
  • marked by a red arrow (left - Revit): Viewport Frame
  • marked by a blue arrow (left - Revit): : Crop Region
If you resize the crop Region in the related views and/or the Annotation crop it will still Export the same current Frame you have as Long as the Level Datum remains as is (ie: extending outside the crop Region)...If you want to resize that Frame to match the actual Crop Region of the related view in Revit you need to (in Revit) go to the related view(s); select and drag the Level Datums to fit them inside the crop region. In such case the Crop Region would be the the actual extent of all elements included in the view (including the Datums) => + or - the viewport
An alternative method is NOT to Export the Viewport category and replace those Frame with a Frame modeled using a Generic Annotation Family or a Details line Family.
As far as I know; the default Crop Region of the Revit view itself will not be exported regradless if it is on a sheet or not on a sheet...I have neither seen this exproted before nor have I ever found Export/Layer Settings for Crop Regions. It is true that there is an article somewhere on the Autodesk Knowledge Network that Claims that CR are exported if placed on Sheets but the Images found in that article do not Support that Claim...it is the viewport extents ...
If anyone knows where that layer setting for crop regions is and/or under which category I would love to hear : o) always open for new ideas
(PS: Crop Regions are not under any category and they are one of those elements in Revit whose visibility can only be overrriden by element)
Nachricht 6 von 9
ams1511
als Antwort auf: barthbradley
Yes, I looked to DWG/DXF Export Setup, and I didn't notice any option related to my issue!
Nachricht 7 von 9
ams1511
als Antwort auf: RDAOU
Thanks RDAOU that is great!!
You solved my issue, thank you very much.
And thanks for every one tried to help
Nachricht 8 von 9
This isn't really a solution for those of us who would like to export "scope boundaries" or "crop regions" to dwg.
Nachricht 9 von 9
rsabclin
Hi - I have same problem. How did you solve the problem? Let me know. Thanks.
