hi,
I am in the process of providing a conditional statement for visibility in family consisting of 3 parameters X, Y, Z.
my requirement is IF X= true, Y=true Z should be false
IF X= true, Y=false Z should be true
IF X= false,Y=true Z should be true
IF X= false,Y=false Z should be false
Can any one please help me in providing a conditional statement as per above function for Z
It should be as below:
IF (X= true, IF (Y= true, Z= false, Z= true), IF (Y= true, Z= true, Z= false))
the words true or false should be treated as strings if needed "true" / "false"
Mostafa Elashmawy
My advice is to use Notepad and write the formula the way programmers would do it (so that you don't get confused). Then, make a condensed form and paste it back to Revit.
if(condition,
result if true,
result if false
Assuming that all parameters are Yes/No parameters, this formula can be assigned to Z. (1=0 will report false, 1=1 will report true).
if(and(X,Y),
1=0,
if(or(X,Y),
1=1,
1=0,
...so, the condensed form would be:
if(and(X,Y),1=0,if(or(X,Y),1=1,1=0,))
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Sorry about the typo, just deleted the comma at the end of the formula
if(and(X,Y), 1=0, if(or(X,Y), 1=1, 1=0, ) )
if(and(X,Y),
1=0,
if(or(X,Y),
1=1,
1=0
if(and(X,Y),1=0,if(or(X,Y),1=1,1=0))
Andrej Ilić
MSc Arch
