Creating two solid forms in the conceptual mass family
2 ANTWORTEN 2
Nachricht 1 von 3
526 Aufrufe, 2 Antworten
I am trying to replicate the columns of toyo itos sendai mediatheque building in the conceptual mass environment.
If you look at the screenshots, this description will make more sense:
Each circle is actually two semi-circles joined together and I want to connect each semi-circle to the corresponding semi-circle above through the create solid tool. However, once i create the first solid, I try to connect the remaining half of the semi-circle with the one above and the first solid dissapears!
Is there a reason why this is happening?
Any help would be appreciated.
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
bin
als Antwort auf: Anonymous
Maybe just selected both circle ( semi-circle *4) and create the form.
Nachricht 3 von 3
constantin.stroescu
I think that the most appropriate way to achieve something like these hollow "columns" from Sendai Center:
would be by using a Generic Model Adaptive family (Adaptive Points)
I made a rough screencast that shows how it can be achieved:
https://knowledge.autodesk.com/community/screencast/16e31210-8bd5-4e3c-87f7-e6758df8e6cc
Constantin Stroescu
