I am trying to create a "shell" with a set thickness xyz data a surface and not a solid in Revit2024.
I presume that I need to use toposurface, but it seems that no longer exists in this version.
Looking through the settings of a toposolid I cannot find a way to have set the thickness for the solid instead of it connecting to a base level.
All help is appreciated.
Gelöst! Gehe zur Lösung
Gelöst von ridantuo. Gehe zur Lösung
Do you mean like this:
Variable off.
