Creating rooms on raised level
3 ANTWORTEN 3
Nachricht 1 von 4
kherrman
222 Aufrufe, 3 Antworten
Have a floor plan where a level is 3'-0" above the working level. The floor plan shows correctly as the cut line is 5'-0" above the working level, but it won't find room boundaries to be able to place a room.
Do I need to create a plan region, or is there a way to set the limits and offsets of the room tag constraints?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: kherrman
Set Room Area computations to area + volume,set the raised floor to be room bounding and draw room separation lines around the raised area if you don't have walls there.
Nachricht 3 von 4
GaryOrrMBI
Go to any view where you can see the level, select it, and use the properties to set the "Computational Height" to 3' or higher:
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Nachricht 4 von 4
Lachlan-JWP
Or place the rooms in a floor plan view that is associated with the raised level. They will still show and be taggable in your original floor plan view if the ranges are correct.
