I am currently trying to create a wall that folds up vertically in Revit 2017. I essentially want to have a hinge (or similar element) along the top portion of the wall that allows it to open vertically. I have enclosed an image that shows the basic motion that I am looking for the wall to do, with the piece of wood attached to the hinges being the wall and the space with the stereo system being the interior space of the building. Thank you for your help and let me know if you need further clarification.
Preston
Thank you for your speedy reply. I need help with creating the part of the assembly that moves. Is there a way to create a hinge system essentially?
Preston
you can make the hang in generic family and import it in the other family containthe movable part
Hi @Anonymous
Check out the recommendations by @L.Maas at the thread HERE where he discussed creating families with hinged parts.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
You could create it with angle parameter(s) to control the rotation of any components. If you are looking for something like a slider to slide up and down to animate the wall opening and closing at various angle then there is no easier way to be done in Revit natively. IMHO if it only to understand and ensure the dimensions and clearances work for the operation then there is no need for such complication.
Edited. Pays to read the post carefully.
Adapt an OOTB Awning window family. CTRL-C>>CTRL-V the geometry into a generic model family, tweak the parameters as needed. Drop it into the model as a model-in-place Wall.
Somebody is over-complicating things.
This is basically just a hangar door. Make a new door family from the standard template. Get rid of the default door surround trim. Then build a swinging panel that adjusts to the default width and height parameters, that's hinged at the top, and that has a new angle parameter to go with that hinging action.
It's no different than any standard door that you want to make an adjustable swing for to show the leaf at various angles, except that it's hinged across the top instead of along a side.
Here is the family.
Default opening angle is set to 0.01 degrees. Don't try setting it to zero. It breaks. Probably also breaks at 180 degrees but I haven't tried it.
I'm not entirely sure what you're trying to say exactly. Slider controls are pretty easy.
Make anything with a control grip and then drive your desired parameter with a formula that somehow relates to the control grip's parameter. That's all.
