I need to create a new parameter ( assigning an existing shared parameter ) in all families under the Curtain panel categories. I have nearly 400 families under the same category. Is there any way to create it instantly in single shot?
If the shared parameter exists in a project as a project parameter, and the parameter applies to the Curtain Panels category, then all the instances of families of such category will show that property.
Yeah U can use up with Dynamo Using the below nodes
Element.GetParameterValueByName
Element.SetParameteValueByName
Kindly check Below script ScreenShot for reference
