Creating new level from the existing name
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1745 Aufrufe, 8 Antworten
there is the way to cancel the extisting level in defaul project to renamed new level I put with the same name?
I cancel the  default elevation (north, south, etc..) in project. Recreate a the north view but don't find default level.
So I put new at 0, 4 and 8 m. When trying to chang e the name (level 0,1,2) project say me are already in use.
How can I cancel the default level definitely o rifind the extisting default level in view?
Thank's.
8 ANTWORTEN 8
Nachricht 2 von 9
thamizhz
als Antwort auf: Anonymous
Please check your hidden objects5.JPG details.. levels hidden another location in same project.
after delete your old levels then you can try.
Nachricht 3 von 9
PijPiwo
If you have some objects that are nowhere to be found, you can create a temporary schedule of that category and delete unwanted objects from there. The same applies to the levels. Go to View tab -> Schedules -> Schedules/Quantities -> Levels. Add to the schedule only one field - a Name (you don’t need more than that).
You can also try to select an object in the schedule and click on Highlight in Model to reveal lost item in the project.
In your case however, levels 1 and 2 are hidden behind levels 0 and 5 in your elevation view.
Nachricht 4 von 9
PijPiwo
als Antwort auf: PijPiwo
@Anonymous, I’m sorry, forgot to mention. Right click on the level -> select all instances -> in entire project (5 should be selected) -> with all levels selected -> right click again -> maximize 3D extents. That will place levels 1 and 2 behind levels 0 and 5 - easier to find them now.
Nachricht 5 von 9
@PijPiwo "@torrenti, I’m sorry, forgot to mention. Right click on the level -> select all instances -> in entire project (5 should be selected) -> with all levels selected -> right click again -> maximize 3D extents. That will place levels 1 and 2 behind levels 0 and 5 - easier to find them now."
Thank's very much for responce.
If click on maximize 3D extents not find the hide level.
Understand instead procedure to delete in schedule.
Nachricht 6 von 9
PijPiwo
After ‘maximize 3D extents’ command:
  1. select a level
  2. unlock
  3. drag a blue circle
  4. Repeat for the other level
Nachricht 7 von 9
Sorry for my obvious questions but, when I cancel the level 1 (default leel), on the base, the walls canceled.
There is a reason? Default level can't be delete?
Nachricht 8 von 9
When you delete a level, anything hosted by this level will be deleted. Why do you need to delete it? Just rename it if you need it to say something else.
Nachricht 9 von 9
als Antwort auf: ToanDN
@ToanDN don't need to cancel.
Just to enderestand.
Thank's to all. Can't give kudos because site don't go well you.
Do after.
Thank's!! :zwinkerndes_Gesicht: :))
