Creating Lighting Fixtures
3 ANTWORTEN 3
Nachricht 1 von 4
269 Aufrufe, 3 Antworten
I work for a small lighting manufacturing company and have been tasked with creating the Revit models for our product line. We have some lighting that is bi-directional and controlled separately. Is there any way that this can be done? I have not found any other models that work like this and when I nest two lights into the fixture I either can not get them to show up or they can not be controlled separately. Does anyone have a good solution for this issue?
Vicky
3 ANTWORTEN 3
Nachricht 2 von 4
L.Maas
als Antwort auf: Anonymous
Not sure how your lights should be modeled. You possibly could use nested families to get what you want. HERE an article on the Autodesk knowledge website which explains it in more detail.
You can pass through parameters from the nested families to the host so you can control them in your project
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 4
als Antwort auf: L.Maas
How do you pass parameters through? I know the basics of it for families from a tutorial I found but most of my Revit use is in doing basic buildings not in making Families. If I could control the parameters of the light output after it has been nested that should work for what we need. I have played around with nesting a light a little bit but havent been able to make it do what we need.
Nachricht 4 von 4
artejon
Here is a link to an article explaining how to associate family parameters ( 'pass parameters through' :enttäuschtes_Gesicht:
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-E2E6B19B-E47F-4F35-9F6D-1273A3248A50
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
