Creating Groups
Creating Groups
Message 1 of 18
Creating Groups
I was having a look at groups to make new ones...all worked well, but I wanted to understand, what is the difference between creating a group of elements and creating a component in family...what are the pros and cons for each?
many thanks in advance.
Replies (17)
Message 2 of 18
Any advise is much appreciated.
Message 3 of 18
Could someone form Autodesk please shed any light on this?
Many thanks in advance!
Message 4 of 18
LisaDrago
Well - i am not from autodesk so you can take this with a grain of salt if you would like.
A group is a collection of components that have certain associativity - like a toilet room - you can set the walls, sink, toilet any ADA requirements in a group and use it over and over in any project you want. You can set the specific distances you need and all that jazz.
A Component/Family - is typically one 'thing' - you can create a desk and that is a component. You can create a toilet and that is a component. You typically do not create more then one complete object in a component.
You can combine all those individual things into a group.
Hope this helps...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
Message 5 of 18
Thahks for that.
I'm new to Revit so trying to understand how this area of the program work...your reply made more sense to me 🙂
How do you copy groups between projects?
Message 6 of 18
LisaDrago
In the project browser you will have a listing for Groups - either Model or Detail - (Model is 3D components and Details is 2D information) you can right click on the specific group and do a Save Group. this will open a dialog box so you can save it to your company library.
I have attached an image of the project browser.
I am glad to help.
LD
Message 7 of 18
Got it!
Thanks Lisa...all worked fine.
Message 8 of 18
LisaDrago
Glad to help -
Don't forget to accept the soultion so people know the issue is resolved.
Have a great night!
LD
Message 9 of 18
jbc
To help keep REVIT file sizes manageable our office uses the practice of keeping groups with-in the file to a minimum. Component families especially when there are multiple copies required use a lot less data. On multi storey apartments we might make up a balcony slab with balustrade as a component or a kitchen, bathroom layout for example.
gjettner
Message 10 of 18
This is also a good idea...Similar to how we worked on Microstation using cell libraries.
thanks for all the help.
Message 11 of 18
i am curious how you create the components
if you do the balcony, you cannot use floors, railings etcetera
you just model everything?
how will revit handle the schedules then? or just count the balcony as one?
Message 12 of 18
LisaDrago
I am a little lost on what you are asking...
In your file you have the balcony floor created the railing created and you can group them together and use that.
Or am i not following what you are asking...
LD
Message 13 of 18
gjettner is talking about use as less groups as posible for speed purpose
and use components instead
but i do not know how to make walls, floors, railings etcetera in one single component only by modeling them all
so i want to know how to do that.....
Message 14 of 18
LisaDrago
Okay - back on the same page again...
You would have to create all of that separately... some of them are system family's like walls, floors and railings... you would only be able to make them in a project.
LD
Message 15 of 18
gjettner
how to make a layout for a bathroom in a component ? must include walls, maybe tiling floor, components as toilet, shower, bath...
easy to put it in a group, but how to put it in a component???
Message 16 of 18
LisaDrago
You would not be able to build all of that in a single component because of system familys like walls and floors - they can only be used or built in a project .rvt file and not a family .rfa file. You would only be able to combine all of those different components in a group which can be exported out and used in a different project. It would be exported as a project file or a .rvt.
Does this make sense or am i out in left field?
LD
Message 17 of 18
jbc
I use a generic model family and make the componants up using simple extrusions. If the balcony floor sla is the same material as the floor slab in the main model then the geometry will join seamlessly. the balustrades can take a bit of time to model depending on the complexity of the design. The down side is yes you can not quantify the extent of the balustrade. I keynote the family so I can schedule the balustrade by type. The attached balony familys are a sample of 10 different balustrade designs used in a 30 storey building. I also use a similar method for kitchen layout cabinet famililies. they are not very detailed but at a 1:100 scale for plans and sections these families provide enough information for that scale and when I need to detail the kitchen in more detail I add the detail in 2D as required. Hope this helps clarify my earlier post.
gjettner
Message 18 of 18
thanks, this explains....!
i did use this before, but i thought you did something else
