Creating Floor Material Legend
anson6WA2Y
anson6WA2Y
Hi, I am creating a landscape material plan and trying to make a legend for different materials (various paver types, planting areas etc.). What I started to do is to create a filled region, but it doesn't really bring the pattern of the floor type I used (paver pattern) onto the legend unless.
I was testing with "Annotate > Detail > Component > Legend Component" and pick the floor type to create a legend, but that way it only gives you the option to use the floor's section as the hatch legend. Any recommendations on how to adopt a plan view of the floor pattern (and the live hatch could automatically update when you change a material type). Thanks!!
Could you clarify your first paragraph? "Unless".. what?
If you're wanting to create a legend for your floor patterns, then wouldn't you just create a filled region using the same 'Surface Pattern' that is used for the material you have on your floor?
You may also need to adjust the scale of your Legend to match that of your floor plan if the pattern used is Model based.
