Creating door / window frame elevations
Sahay_R
Mentor Mentor
Message 1 of 15
Sahay_R
Hello all,
In a previous job I remember there being an elevation type that creates Frame Elevations.
I am attempting to replicate that. I would like to create elevations for Doors, Windows, and Curtain Wall glazing. What settings would I need to create in my View Template and Filters? Anything else that I would need to create in this elevation type?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (14)
Message 2 of 15
zemeraloni
Hi @Sahay_R
Maybe you  are looking for legends that you  drag family from the browser to them and it's create a plan/elevation of the family?
i"m not sure that it"s possible in curtain system panels
Message 3 of 15
What you remember is The structural framing elevation from the elevation view dropdown. I don't think it has anything to do with door and window frame elevation. Do you want to create door and window elevation legends?
Message 4 of 15
Doors and windows, legend views for sure.
Curtain walls, I used to do elevations and filter out everything but curtain wall elements using VV/VG to start. Then use the sunglasses to isolate the elements just to be sure. A very manual process as I would need to create and track a lot of elevations. When things changed, I needed to check and adjust view crops and extents and make sure no new curtain walls get into the view.
I would try using assemblies if I needed to do it again. You can't add curtain walls or grids to assemblies, but you can select the mullions and panels which give shows everything you need for a legend.
Message 5 of 15
I do use Assemblies for Curtain Walls legend and it works wonder.  Keep in mind that Mullions and and Panels can be added to an assembly, but not the Curtain wall itself.
Message 6 of 15
When you use actual elevations for your legends, you want to create them in a detail phase.  This phase would be demolished before the Existing Phase.  That way nothing shows up when your users start modeling a new project.
This works for generic elevations and details, if you need actual project details I use a future phase.  That way the elevation bugs don't show up on my plans all over the place.
Message 7 of 15
Sahay_R
Thank you, all. What I had experienced (and want to duplicate here) is that you place an elevation tag and it spits out an elevation. I am not talking about Legends, because we also need to create elevations of curtain walls. The approach that I am experimenting with is an elevation type, controlled by view template that only displays Doors, Windows, Curtain wall stuff, and Walls (to show the Curtain Walls - other wise nyet), and possibly a filter to filter out regular walls and leave Curtain Walls visible.
Rina Sahay
Message 8 of 15
Use Assembly tool. It is great for what you do. No need to messing around with elevation labels, view template, etc...
Message 9 of 15
Sahay_R
@ToanDN - tell me more...
Rina Sahay
Message 10 of 15
See screencast in a few minutes.
https://knowledge.autodesk.com/community/screencast/d4d0ebe6-1f09-45d7-93f6-9cf9fdb35fc5
Screencast will be displayed here after you click Post.
Message 11 of 15
Sahay_R
@ToanDN this is great - but Assemblies don't work with a Curtain Wall that has a door in it....
Been there tried that
Rina Sahay
Message 12 of 15
They do.  I just swapped the panels with a door and a window and the assembly views updated instantly.
Message 13 of 15
loboarch
You can duplicate an existing elevation type and make a new one that automatically applies a view template when created. Then in the view template apply V/G overrides to turn off visibility of all categories except windows, doors, and curtain walls.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 14 of 15
Sahay_R
@ToanDN - when I selected my curtain wall with the door, Assemblies thew a fit at me. Or maybe I should try to create the Assembly first and add the doors later
@loboarch - I'm beginning to think that this is the approach that would serve us best
Updates when I'm back in the trenches tomorrow......
Rina Sahay
Message 15 of 15
Make sure you filter our (Curtain) Walls and Curtain Grids. Only Mullions, Panels, Curtain Wall Doors, and Curtain Wall Windows should be selected when create Assembly.
If you end up using elevation with filter for Legend, make sure users don't accidentally move or modify what on the Legend because it is the actual part of your model.  Using Assembly, it's almost bullet proof.  You cannot delete or move the assembly from the view, only from the Assembly browser.  And deleting Assemblies from the browser doesn't affect the original source model.
