CREATING DETAILED TOPO FROM CAD FILE
5 ANTWORTEN 5
Nachricht 1 von 6
mimhuseyiny
302 Aufrufe, 5 Antworten
Hi, I insert my cad file including contour lines with correct heights. When I create a topo surface from that file after importing, Revit creates it with basic lines. I want to make it much more detailed which should have points on every corner at the contour lines. Is it possible?
5 ANTWORTEN 5
Nachricht 2 von 6
EATREVITPOOPCAD
als Antwort auf: mimhuseyiny
I believe you have to play with additional Model & Site settings by clicking the little arrow.
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 6
You are never going to match the contours exactly.  Close, yes. Exact, no.  Been there, tried like hell, gave up.
....BTW, the contour-looking linework you see in Toposurface Edit Mode is not indicative of how the contours will display outside of Edit Mode.  @EATREVITPOOPCAD is spot on.
Nachricht 4 von 6
Try to create the topo from a point file instead of a CAD file, even though they are from the same Civil3D source.
Nachricht 5 von 6
mimhuseyiny
als Antwort auf: ToanDN
I tried it. It's better with it but not close enough to the desired result. So, I created it manually.
Nachricht 6 von 6
mimhuseyiny
Thanks for your suggestions guys!
