Creating another Color Filled Legend to a project
1 ANTWORT 1
Nachricht 1 von 2
jim3thornton
454 Aufrufe, 1 Antwort
I have been able to create one Color Filled Legend that shows Occupancy Types ...
this was designed to show the various occupancy types on this floor plus I also wanted to show the 2nd Rated Spaces.
I defined the Occupancy for each room I wanted to express.
These Colored Filled Legends were used our Code Analysis Sheets ....
Now I would like to create a 2nd Color Filled Legend that would only highlight the 1-HR Corridors and 2-HR shafts ... I do not want to display the occupancy types ...
This Legend would exist on the Floor Plan Sheets ... which are separate from the Code Analysis Sheets
Is this possible for when I have tried to create a 2nd Colored Filled Legend ... it has changed the properties of the 1st one.  Basically it was still the original Color Filled Legend.
1 ANTWORT 1
Nachricht 2 von 2
Alfredo_Medina
als Antwort auf: jim3thornton
@jim3thornton
You need to create a project parameter that applies to rooms. Then, in the Color Scheme dialog box, create a new Color Scheme, based on that Project Parameter. Enter colors or fill patterns. Then, in a new floor plan view, apply this color scheme to the floor plan. Then, enter values such as 1H or 2H to the rooms. Then apply this Color Scheme to the view. This will not affect the other view that has the other color scheme by Department.
