Creating and Trimming Roofs
BugFinder
Message 1 of 13
BugFinder
I'm trying to recreate a roof and am having trouble with it as it is a peculiar shape.
Probabily best to start with what I have:
The first issue is that the roof is disconnected at highlighted square 1 even though this section of the roof is drawn as a single part:
How can I do correct this?
The second issue is to do with highlighted square 2.  Because the roof is on different levels (pitch up to main building and section previously described) I've had to do this in two parts (they are also different levels too).
So, how do you trim the roofs together so that I don't get one roof pitch under the other?  I want to attach the wall to the roof but at the moment it wont let me.
Since this is quite a complex shape, this is what it's supposed to look like:
Any help is appreciated.
Accepted solutions (3)
Replies (12)
Message 2 of 13
Can you share the model?
Message 3 of 13
Model them separately and them join them.  If it's an over-frame condition, that's how they will build it in the field.
...if it is an over-frame, the gable roof is probably going to look exact like you have shown.
Message 4 of 13
BugFinder
@ToanDN I'd preder not to make public however would be willing to PM.
@barthbradley I'll give that a go...
Message 5 of 13
PM is fine but sharing a stripped down model with maybe just the roof here would give a fair chance for others to look at as well.
Message 6 of 13
BugFinder
@ToanDN never thought of stripped down Smiley Happy
Assuming there is no easy stripdown function which I should have used, I've been through and manually deleted all the features and attached file.
Message 7 of 13
I'm envisioning something like this
Ah! I see. Just delete the define slope from yours...
Message 8 of 13
constantin.stroescu
is that what you want?
Constantin Stroescu
Message 9 of 13
I don't have 2017 so I will show you how it be done via a screencast in 2018 in a few minutes.
https://knowledge.autodesk.com/community/screencast/9eee0158-1c02-41e1-a21d-143c756a8aef
Message 10 of 13
it is a single roof by footprint
cut a small segment and uncheck  the slope for it..
Constantin Stroescu
Message 11 of 13
Message 12 of 13
constantin.stroescu
and the screencast that shows the steps:
https://knowledge.autodesk.com/community/screencast/d3f31339-d300-4b38-b01d-280da8cdc40a
Constantin Stroescu
Message 13 of 13
BugFinder
Great!!  I now have an working solution...
Many thanks for your help and assistance guys. Very much appreciated Smiley Happy
