Creating and tagging a schedule from a linked model
sstattelman4GLLM
sstattelman4GLLM
Is it possible to generate a schedule from a linked model and tag the elements from the linked model with multi category tags.
To give context I have furniture in a model that is linked in to the architectural model which just has walls and doors. I want to label the furniture with a multicategory tag that feeds back to a schedule of the linked model showing exactly what type and label each piece of furniture is. Is this possible at all in revit? Trying to wrap my head around it
SteveKStafford
A schedule in your host model can include elements in a link, so a furniture category schedule can include the furniture in the linked model and report any Furniture category parameter values that have been used in the furniture families . You can also apply a furniture category tag to furniture elements contained in either your file or a linked model. Assuming all the linked file's furniture is assigned to the furniture category you don't need a multi-category tag or schedule, just a furniture schedule. If they aren't all assigned to furniture then a Multi-category schedule can include furniture but you'll need a way to filter out other category elements and you'll also have far few options for parameters to include because only parameters that all categories use will be available.
Steve Stafford
sstattelman3TGJG
Steve I think this makes sense. Currently have the list of furniture / equipment and it is coming from the tags from the linked model. Not sure how I would go about tagging this, but I may just need to take a deeper dive into how tags and multi category tags actually work. Thanks for the help!
sstattelman4GLLM
Ended up being much easier than I thought. Just added the shared parameter tag to the multicategory tag and was able to tag anything I needed. Thanks!
